Java-Problem
  • Java-Appi
  • 29. Februar 2004 um 15:05
  • Java-Appi
    Java-Appi
    Hallo liebe Leute,
    ich habe ein kleines Java-Programmierungsproblem. In dem unten stehendem Quellcode müsste die monatliche zahlung bei jedem Output stehen. Nun ist meine Frage.
    Wie kann ich die monatliche Zahlung in jedem der 3 Ausgaben einfügen?
    Vielen Dank für schnelle Antworten
    grüsse
    //Mortgage Program /
    //This program will calculate and display the mortgage /
    //monthly payments for three different loans given the /
    //amount, the term and the interest rate of the mortgage. /
    //Hardcoded amounts are provided by the instructor. / /
    //Version 1 /
    //Modification 1 /
    //This program has been modified to display 3 mortgage loans,/
    //7 year at 5.35%, 15 year at 5.5%, and 30 year at 5.75%, /
    //using an array for the different loans. In addition, this /
    //program will display the mortgage payment amount for each /
    //loan. /
    //Version 1.1 /
    //To set digits after decimal point//
    import java.text.NumberFormat;
    class MortgageArray {
    public static void main(String args[])throws InterruptedException
    double principal = 200000; //Hardcoded amounts//
    double []percent = new double [3];
    percent[0] = 5.35/100;
    percent[1] = 5.5/100;
    percent[2] = 5.75/100;
    short []nyears = new short[3];
    nyears[0] = 7 ;
    nyears[1] = 15;
    nyears[2] = 30;
    //Used to set two digits after decimal point//
    NumberFormat fmt = NumberFormat.getInstance();
    fmt.setMaximumFractionDigits(2);
    fmt.setMinimumFractionDigits(2);
    //Displays Results
    System.out.println("\nPrincipal = $" + fmt.format(principal) + "\nInterest = "
    + percent[0] + "%"
    + "\nYears = " + nyears[0]);
    System.out.println("Monthly Payments = $ " +fmt.format(pmt));
    + percent[1] + "%"
    + "\nYears = " + nyears[1]);
    System.out.println("Monthly Payments = $"+fmt.format(pmt));
    + percent[2] + "%"
    + "\nYears = " + nyears[2]);
    //Formula calculations to figure monthly payments//
    //Principal= 200000*(5.75/(1-(1+5.75)^-360))//
    //Reference Chou, H.(2000)US Mortgage formula//
    double intmo = percent / 12;
    int npmts = nyears * 12;
    double pmt = principal * (intmo / (1 - Math.pow(1 + intmo, -npmts)));
  • Zentor
    Zentor
    • 29. Februar 2004 um 16:28
    Ich versteh deine Frage nicht, kannst du das genauer formulieren? Ansonsten is da einiges ziemlich unlogisch und falsch. Ich vermute Mal du wolltest das hier:
    for (int gg = 0;gg<3;gg++)
    double intmo = percent[gg] / 12;
    int npmts = nyears[gg] * 12;
    + percent[gg] + "%"
    + "\nYears = " + nyears[gg]);
    mfg Zentor
  • Java-Appi
    Java-Appi
    • 29. Februar 2004 um 20:20
    Vielen Dank für die schnelle Antwort.
    Das war die Korrekte lösung. Nächstes mal drücke ich mich noch deutlicher aus :thumb: .
    Schönen Wochenanfang noch
    gruß
    J-Appi
  • Java-Appi
    Java-Appi
    • 1. März 2004 um 21:04
    Hallo Zentor,
    ich habe noch ein Problem mit einem Code. Könntest Du ihn dir Bitte ansehen und mir sagen wo das Problem steckt.
    Vielen Dank im vorraus
    //monthly payments for a loan given the /
    //Version 1 /
    //Modification 1 /
    //This program has been modified using an array to display /
    //3 mortgage loans: 7 year at 5.35%, 15 year at 5.5%, and /
    //30 year at 5.75%. In addition, this program will display /
    //the mortgage monthly payments amount for each loan.
    //Modification 2
    //This program will list the loan balance and interest paid for
    //each payment over the term of the loan
    //Version 3.2 /
    class MortgageArray1
    nyears[0] = 7 ;
    nyears[1] = 15;
    nyears[2] = 30;
    int delay = 1;
    //Loop to displays results for each loan//
    //Principal= principal*(percent/(1-(1+percent)^-years))//
    for (int x = 0; x < 3; x++)
    double intmo = percent[x] / 12;
    int npmts = nyears[x] * 12;
    + "\nInterest = "
    + percent[x] + "%"
    + "\nYears = " + nyears[x]);
    System.out.println("Monthly Payments are = $ "
    + fmt.format(pmt));
    //Formula calculations to figure interest pay in
    //each monthly payment and the balance afterwards//
    for (int x = 1; x <= npmts; ++x) {
    double prinpmt, intpmt = principal * intmo;
    if (x < npmts)
    prinpmt = pmt - intpmt;
    else prinpmt = principal;
    principal -= prinpmt;
    //Display results//
    System.out.println(x + "\t\t" + fmt.format(intpmt + prinpmt)
    + "\t" + fmt.format(intpmt)
    + "\t" + fmt.format(prinpmt)
    + "\t\t" + fmt.format(principal));
    //Used to display line by line with hesitation time//
    if (delay == 1)
    Thread.sleep(1000);
    delay = 1;
    Thread.sleep (1000);
  • Zentor
    Zentor
    • 1. März 2004 um 22:55
    Sorry, aber ich löse sicher nicht alle kleinen Problemchen für dich. Programmieren braucht nun mal Zeit und Hirnschmalz... Du schaffst das schon :winking_face:
    mfg Zentor
    • 2. März 2004 um 02:04
    mfg Zentor
    Lustig wirds, wenn man mal genau weiß, dass man die einzige Person auf der Welt ist, die ein spezielles Problem lösen kann (ohne sich mal ein oder zwei Monate einzuarbeiten)...
  • JohnFoo
    JohnFoo
    • 3. März 2004 um 14:57
    In diesem Forum wird den Leuten eh schon bei Fragen geholfen, die in Newsgroups wie comp.lang.java.help ignoriert werden würde.
    Manchmal hat man einfach den Eindruck, dass der Poster bissl zu gemütlich lebt, um sich selber mit der Aufgabe zu beschäftigen ..
    Und wo wir schon dabei sind: Manchen Posting-Titeln wie
    Java-Problem
    fehlt etwas die Aussagekraft .. usw usf How To Ask Questions The Smart Way kann ich da nur empfehlen.
  • marX
    marX
    • 3. März 2004 um 19:16
    also um jetzt mal ganz böse zu sein:
    ich glaub nicht, dass er sich auch nur ein bisschen mit programmieren auskennt!! -> er schmeisst (kopiert) nur java codes mit englischen kommentaren die er eh nicht ganz versteht) hinein und hofft jemand nimmt ihm die hausaufgabe ab, weil er zu faul ist um sich selbst hineinzuarbeiten!
    tut mir wirklich leid, dass ich so böse sein muss (eigentlich nicht *gg*) aber es hat mich schon immer geärgert, wenn jemand absolut keine ahnung hat, zu faul ist um selbst nachzudenken, sich die codes von überall zu sammenklaut und dann noch nicht mal selbst die kleinen ungereimtheiten der verschidenen code-teile abändern will!!
    hal: also 1-2 monate ist (für die ganze welt) schon etwas viel :winking_face: -> es gibt schon ne ganze menge brutale pc-junkies auf der erde ;)!
    von was für einem programmierproblem sprechen wir überhaupt ??? :)
    mfg marX
    ps: noch was für "java-appi": wie wärs wenn du wenigstens das code-tag ([ code] ... [ /code])verwenden würdest um "deine" codes etwas übersichtlicher zu machen (vor allem wengen der kommentare!)!!
    • 3. März 2004 um 19:57
    Naja, das passiert vor allem, wenn man ungewöhnliche Technologien miteinander kombiniert. zB DVB-S und FireWire unter Mac OS X, so wie in meinem letzten großen Projekt.
  • marX
    marX
    • 3. März 2004 um 20:20
    ok .. wenn man natürlich selbst sehr komplexe schnittstellen definiert und diese noch mit anderen verknüpft gibt's sicher nicht mehr viele, die da den vollen durchblick haben :winking_face:
    ich glaube aber, dass ein echter checker der unter macOS viel mit firewire arbeitet (programmiert) sich da in ein paar tagen genügend eingelesen hat!
    na ja wie auch immer :)
    mfg marX
    • 3. März 2004 um 20:51
    Unterschätz DVB nicht. Es gibt mehrere tausend Seiten an Spec zum durchlesen (das inkludiert den kompletten MPEG2-Standard!), die auch noch dazu erst mühsam zusammengeklaubt werden müssen.
    Falls jemand einen Job zu dem Thema hat: Ich kenn mich inzwischen sehr gut damit aus :grinning_squinting_face:
  • Java-Appi
    Java-Appi
    • 3. März 2004 um 21:13
    Okay Leute,
    ich Poste gerade mal 2 Sachen hier in das Forum und schon glaubt Ihr mich zu kennen... LOL... sag ich nur.
    Okay ich gebs zu, ICH bin nicht der Beste Programmierer. Ich bin gerade in einer Online-Universität in dem Java-Kurs für Anfänger. Dort ist nunmal alles auf Amerikanisch. Und da ich ein Amerikaner bin hab ich auch keine Probleme die Texte (Aufgabenstellungen) zu verstehen. Diese Codes wurden von mir persönlich erstellt und nicht von irgendwo "zusammengeklaut"... Aber Denkt doch bitte was Ihr wollt.
    Ein wenig hilfe hätte ich schon erwartet von so "erfahrenen" Programmierern wie "euch".
    Hier ist ein Update von meinem Programm. Dort habe ich nun noch einen Fehler. Zwar dass ich eine Endlosschleife erstellt habe und ich nicht weiss wie ich diese anhalten kann. Vielleicht kann mir Bitte ein Hilfsbereiter Programmierer weiterhelfen.
    vielen Dank im vorraus
    Java-Appi
    Java
    //Version 1												  /
    //Modification 1											 /
    //the mortgage monthly payments amount for each loan.		/											   /
    //and display the mortgage payment amount, and the interest  /
    //paid for each payment over the term of the loan. To include/
    //the balance after each payment. The program will use loops /
    //to display a partial list, hesitates and display more of   /
    //the list												   /
    //Version 3.1.1											  /
       double []percent = {5.35/100, 5.5/100, 5.75/100};
       short []nyears = {7, 15, 30};
    	 getmonthly(principal, percent[x], nyears[x]);
       public static void getmonthly(double principal,double percent, short nyears)throws InterruptedException
    	for (short mo = 1; mo <= npmts; ++mo) {
    	   if (mo < npmts)
    	 + "\nInterest = "
    	 + percent*100 + "%"
    	 + "\nYears = " + nyears);
    	 + fmt.format(pmt));
    	//Display results//
    	System.out.println(mo + "\t\t" + fmt.format(intpmt + prinpmt)
    	int delay =1;
    	if (delay == 1)
    	   Thread.sleep(800);
    }//End of Mortgage program//
  • JohnFoo
    JohnFoo
    • 4. März 2004 um 00:30
    Manche Menschen sind leicht durchschaubar.
    Richtig. Anders gesagt: Eine Null. Zu faul sein eigenes Programm vertehen zu wollen ..
    Na dann fragt sich, wieso du in einem österreichischen Forum um Hilfe bettelst.
    Und du verstehst deinen eigenen Code nicht mehr, und bittest andere, dir zu helfen?
    Erwarten solltest du dir genau gar nichts. Wenn dir jemand hilft, dann darum, weil ihm danach ist. Und das heißt: Entweder er hat einen guten Tag, oder macht einfach gerne die Hausaufgaben für jemand anders. Oder dein Problem ist fordernd und reizt den Leser, es zu lösen. Ansonsten: RTFM und STFW.
    Nachdem du uns ja als "erfahrene" Programmierer bezeichnest, kannst du dir viel Hilfe erwarten. Sei froh, dass dir Zentor schon so weit geholfen hat ..
  • CitizenX
    CitizenX
    • 4. März 2004 um 00:49
    Wieso seid ihr eigentlich so gehässig ? Wenn ihr ihm/ihr nicht helfen wollt schließt das Fenster doch einfach wieder und ignoriert den Thread .... oder is das ein flamewar Versuch ? die ham in diesen Forum noch nie wirklich funktioniert :winking_face: :grinning_squinting_face:
    Greets X :coolsmile
  • JohnFoo
    JohnFoo
    • 4. März 2004 um 01:25
    Manche Leut' stellen sich so dumm an, dass es besser ist, sie auf ihre Fehler hinzuweisen, als einfach wegzuschaun ;).
    oder is das ein flamewar Versuch?
    Aber sicher doch :grinning_squinting_face: - damit der Thread schön lang wird ..
    Naja, versuchen kann man's.
  • The_1
    The_1
    • 4. März 2004 um 09:54
    Ich denke das ist hier das eigentliche Problem. Alles eine Frage der Formulierung. Hätte Java-Appi gesagt: Ich hab hier diesen Code geschrieben, und es läuft dies und das falsch, kenn mich nicht mehr aus, kann mir jemand helfen, hätten sich sicher genügend hilfsbereite Informatiker (wir sind ja nunmal von Natur aus sehr hilfsbereite, unglaublich freundliche und überaus charmante Menschen)
    Aber die oben verwendete Formulierung lässt einen glauben, Java-Appi hätte sich den Code tatsächlich irgendwo rauskopiert, ihn nicht mal gelesen und er hofft jetzt dass dies jemand anderer für ihn tut. Auch wenn dies vielleicht nicht zutreffen mag, das Gefühl kriegt man trotzdem.
    Man sollte immer versuchen demjenigen von dem man Hilfe erwartet, so viel Arbeit wie möglich abzunehmen, z.B. in dem man in zumindest auf die Exception bzw. den Fehler hinweist der vom Programm gemeldet wird. Sachen wie "Könntest du bitte den hier geposteten Code in ein .java File kopieren, ihn kompilieren, anschauen welche Fehler er liefert, dann den ganzen Code durchlesen, und schlussendlich den Fehler finden",die sind einfach unangebracht.
    Valerio!
  • JohnFoo
    JohnFoo
    • 4. März 2004 um 13:06
    Stimme zu.
  • marX
    marX
    • 4. März 2004 um 18:26
    also wenn ich mir jetzt deinen code mal kurz anschaue bemerke ich folgendes:
    1. "{" ... "}" blöcke OHNE if, for oder so was
    2.
    int delay =1;
    if (delay == 1)
    { Thread.sleep(800); }
    ergibt für mich auch nicht wirklich viel sinn!!
    solche fehler kommen typischerweise vom zusammenkopieren von code-fragmenten, bzw. wenn jemand wirklich absolut keine ahnung hat, dann verstehe ich jedoch folgendes nicht:
    bzw.
    -> also da muss ich johnfoo recht geben: manche menschen sind (auch wenn sie es nicht wahrhaben wollen) wirklich leicht zu durchschauen ;)!
    um trotzdem noch kurz auf deine frage einzugehen:
    (7+15+30)*12*sleep(800) ergibt sage und schreibe über 8 minuten!
    und wenn dann jemand natürlich nicht weiß (weil das programm nicht selbst geschrieben wurde ?!!!!), dass system.out.println in die konsole schreibt denkt sich dieser logischerweise, mit der zeit: "hm ... warum beendet das prog nicht ?!! ... habe ich da eine endlosschleife ??" -> eigentlich müsste dieser aber wissen, dass mehere 100erte ausgaben (mit je einer verzögerung von 800ms) doch eine zeit brauchen (zumindest wenn er wüsste, was er SELBST programmiert hat!)!!
    @Citizen X: nein so war/ist das NICHT gemeint, aber ich hatte schon zu viel mit solchen code-klauern zu tun, die zu faul sind selbst nachzudenken und dies ist hier so was von offensichtlich ;)....nimms mir aber bitte nich böse :)
    hal: ich würde dich sofort einstellen :grinning_squinting_face:
    The_1: da hast du vollkommen recht;) wenn mich jemand nett bittet und ich sehe, dass er wirklich hilfe braucht, aber seine mittel ausgeschöpft hat, wäre ich sicher der letzte der im diese verwehren würde!!! in diesem fall ist es aber für mich eindeutig (egal was er dazu sagt), dass er keine ahnung von dem code (den er angeblich selbst geschrieben hat) hat!
    mfg marX
  • Java-Appi
    Java-Appi
    • 4. März 2004 um 19:06
  • marX
    marX
    • 4. März 2004 um 20:03
    *gg* na er kann zwar den post überschreiben, aber das mail kann er nicht mehr löschen:
    Zitat von Java-Appi
    Wisst Ihr was... Vergesst es einfach. Geht wieder euren normalen weg. Vergesst das ich jemals was gefragt habe.
    Hoffentlich seid Ihr nicht auch so im "real" live... Wär ja unerträglich.
    Naja Österreicher eben. No Comment.
    have a nice live
    j-p
    ...also ich glaube das untermauert meine these :winking_face:
    mfg marX
