java script code
  • zidane
  • 17. August 2004 um 00:46
  • zidane
    zidane
    hallo
    ich habe den code nicht selber programiert !
    ich will den code erweitern (mehr links) i
    /*anfang*/
    <body>
    </body>
    </html>
    <style type="text/css">
    a:link, a:visited, a:active, a:hover{text-decoration:none}
    </style>
    <script language="JavaScript">
    if (!document.layers){
    // Choose size and colours here!!!!!!!!!!!!!!!!!!!!!!!!!!
    Width=120;
    Font='Verdana';
    FontSize=15;
    AFontColor='#FFFFFF';
    BFontColor='#FFFFFF';
    CFontColor='#FFFFFF';
    FontWeight='normal'; //normal or bold!
    BackGround='#000000'; //Same as your body bgcolor!
    BorderDepth=3;
    BorderLight='#FF0000';
    BorderShad='#FF0000';
    //Nothing needs altering past here!!!!!!!!!!!!!!!!!!!!!!
    function On(id){
    with(id.style){
    color=BFontColor;
    borderTopColor=BorderLight;
    borderLeftColor=BorderLight;
    borderRightColor=BorderShad;
    borderBottomColor=BorderShad;
    function Off(id){
    with(id.style){
    color=AFontColor;
    borderTopColor=BackGround;
    borderLeftColor=BackGround;
    borderRightColor=BackGround;
    borderBottomColor=BackGround;
    function Down(id){
    with(id.style){
    color=CFontColor;
    borderTopColor=BorderShad;
    borderLeftColor=BorderShad;
    borderRightColor=BorderLight;
    borderBottomColor=BorderLight;
    function Link(Url,Txt){
    document.write("<a href='"+Url+"'>"
    +"<div style='position:relative;"
    +"width:"+Width+"px;height:"+FontSize+"px;"
    +"border-width:"+BorderDepth+"px;"
    +"border-color:"+BackGround+";"
    +"border-style:solid;"
    +"padding:"+FontSize/3+"px;"
    +"background:"+BackGround+";"
    +"font-family:"+Font+";"
    +"font-size:"+FontSize+"px;"
    +"line-height:"+FontSize*1.2+"px;"
    +"font-weight:"+FontWeight+";"
    +"text-align:left;"
    +"color:"+AFontColor+";"
    +"margin-top:2px;"
    +"cursor:hand'"
    +"onMouseOver='javascript:On(this)'"
    +"onMouseOut='javascript:Off(this)'"
    +"onMouseDown='javascript:Down(this)'>"
    +Txt+"</div></a>");
    function Temp(){
    alert("TEST");
    </script>
    <!-- End Menu Buttons Part:1 -->
    <!-- Menu Buttons Part:2 Paste in Body where needed -->
    //This table stops oddness in NS6!!!
    if (document.getElementById&&!document.all){
    document.write("<div style='position:relative'>"
    +"<table border='0' cellpadding='0' cellspacing='0'>"
    +"<tr><td valign='top'>");
    /* The visible Buttons here!
    Add as many as you want. Make sure
    you follow the same format as below
    eg: Link('MyOtherPage.html','See my other page');
    Link('http://www.yahoo.com','Yahoo');
    Link('http://www.google.com','Google');
    Link('http://www.altavista.com','Alta Vista');
    Link('http://www.lycos.com','Lycos');
    Link('http://www.hotbot.com','Hotbot');
    document.write("</td></tr></table></div>");
    </script>
    /*ende*/
  • Guardian
    Guardian
    • 17. August 2004 um 08:58
    Hallo Zidane!
    Gibts die Seite auch funktionierend?
    Irgenetwas fehlt hier nämlich, weil alleine der Code nicht funktionstüchtig ist.
    :confused:
    00010011100010001010100111000
    {a,b,b} = { *tilt* } :ahhh:
  • zidane
    zidane
    • 17. August 2004 um 13:31
    </html>
    </style>
    Width=120;
    Font='Verdana';
    FontSize=15;
    DFontcolor='#FFFFFF';
    BorderDepth=3;
    function On(id){
    with(id.style){
    color=BFontColor;
    function Off(id){
    with(id.style){
    color=AFontColor;
    function Down(id){
    with(id.style){
    color=CFontColor;
    function Down(id){
    with(id.style){
    color=DFontColor;
    +"text-align:left;"
    +"margin-top:2px;"
    +"cursor:hand'"
    +Txt+"</div></a>");
    function Temp(){
    alert("TEST");
    </script>
    </script>
    :thumb:
  • a9bejo
    a9bejo
    • 17. August 2004 um 17:54
    hmm, wo genau liegt das problem?
    füg doch einfach einen link hinzu:
    Link('http://kafka.pdi.at:8080','kafkaesk');
    steht sogar im kommentar drüber, das man das machen kann...
    :confused:
  • JohnFoo
    JohnFoo
    • 17. August 2004 um 22:23
    Ich hoffe du verwendest diesen Code nicht freiwillig, sondern wirst genötigt dazu. Ist nämlich furchtbar, so eine Lösung zu benutzen.
    Und interessant wäre ja noch, was JavaScript mit Java oder J2EE zu tun hat. Für diese Erklärung würden so einige was geben ..
  • zidane
    zidane
    • 18. August 2004 um 01:20
    warum ist der code schlecht!
    ich habe mir vorgenommen nächstes monat javascript zu lernen .
    ist es notwendig (java) vorkenntnise zu haben ???
    hängt davon ab was die leute für die erklärung geben
    :grinning_squinting_face::thumb:
    • 18. August 2004 um 02:47
    Das einzige, was JavaScript und Java gemeinsam haben sind die 3 Buchstaben J, a und v. JavaScript heißt offiziell jetzt ECMAScript, um weitere Verwechslungen zu vermeiden.
  • zidane
    zidane
    • 18. August 2004 um 03:59
    ok,danke für die antwort.
    :thumb:
  • JohnFoo
    JohnFoo
    • 18. August 2004 um 12:56
    Hm ja streng genommen ist JavaScript Netscapes Implementierung von ECMAScript. Microsoft nennt seine Implementierung ja JScript, die beiden waren nicht immer kompatibel. Wie es heute so ist, davon weiß ich nichts. Wenn noch Unterschiede, dann wohl in Kleinigkeiten.
    JavaScript wird auf dem Browser ausgeführt und kann vom User abgeschalten werden. Angeblich hat 1/3 der Internet-User JavaScript ausgeschalten. Dein buntes Menü könnte also gar nicht aufgebaut werden.
    Client-seitige Überprüfung von User-Eingaben hat auch wenig Sinn, da sie Server-seitig sowieso noch mal passieren muss.
    Meiner Meinung nach sollte eine Website ohne JavaScript auskommen. Die Verwendung von JavaScript sollte lediglich den Benutzerkomfort erhöhen.
    Bevor du deine Zeit an JavaScript verschwendest, lern' besser Java oder PHP ..
  • Guardian
    Guardian
    • 18. August 2004 um 14:23
    :grinning_squinting_face: :thumb:
    ok anders gefragt, was willst du erreichen mit deinem code, was ist dein ziel,
    weil wie oben erwähnt wurde ist er nicht gerade repräsentativ
    oder anders gesagt ein wenig unschön
