WEB entwicklung, probleme mit GridView
  • Thomas78
  • 18. Februar 2011 um 07:06
  • Thomas78
    Thomas78
    hier erstmal der Code :
    C#
    using System;
    using System.Collections.Generic;
    using System.Data.SqlClient;
    using System.Configuration;
    //using System.Web.UI.WebControls;
    using System.Drawing;
    using System.IO;
    using System.Data;
    public partial class MainSite : System.Web.UI.Page
        ConnectionStringSettings connectionInfo;
        DataTable datTable;
        List<ProduktAktion> aktList;
        Image noPicture;
        protected class ProduktAktion
            Image picture { get; set; }
            String description { get; set; }
            String mixes { get; set; }
            String unit { get; set; }
            String price_original { get; set; }
            String price_aktion { get; set; }
            protected internal ProduktAktion(Image new_pic, String new_desc, String new_mixes, String new_unit, String new_price_or, String new_price_akt)
                picture = new_pic; description = new_desc; mixes = new_mixes; unit = new_unit; price_original = new_price_or; price_aktion = new_price_akt;
        protected void Page_Load(Object sender, EventArgs e)
            if (!Page.IsPostBack)
                GridViewAktion.DataBind();
        protected void GridView_Load(object sender, EventArgs e)
            noPicture = Image.FromFile(@"C:\Users\Thomas\Documents\Visual Studio 2010\WebSites\SchTeddUndMehr\noImage.bmp");
            aktList = new List<ProduktAktion>();
            connectionInfo = ConfigurationManager.ConnectionStrings['RefToDatabase'];
            SqlConnection connection = new SqlConnection(connectionInfo.ConnectionString);
            SqlCommand selectCommand = new SqlCommand("select Bild, Beschreibung, Menge, Einheit, Preis_netto, Rabatt, MWST, Aktion, Aktiv from Produkte", connection);
            selectCommand.Connection.Open();
            SqlDataReader dataReader = selectCommand.ExecuteReader();
            double dnormalPrice;
            decimal normalPrice, aktionPrice;
            Image aPic = null;
            datTable = new DataTable();
            datTable.Columns.Add("Bild");
            datTable.Columns.Add("Beschreibung");
            datTable.Columns.Add("Menge");
            datTable.Columns.Add("Einheit");
            datTable.Columns.Add("Preis normal");
            datTable.Columns.Add("Preis jetzt");
            while (dataReader.Read())
                if ((bool)dataReader['Aktion'] && (bool)dataReader['Aktiv'])
                    dnormalPrice = (double)dataReader['Preis_netto'] * ((((double)(int)dataReader['MWST']) / 100) + 1);
                    normalPrice = (decimal)dnormalPrice;
                    aktionPrice = (decimal)(dnormalPrice - (dnormalPrice * (double)dataReader['Rabatt'] / 100));
                    if (System.DBNull.Value != dataReader['Bild'])
                        Byte[] bytePic = new Byte[0];
                        bytePic = (Byte[])dataReader['Bild'];
                        MemoryStream streamPic = new MemoryStream(bytePic);
                        aPic = Image.FromStream(streamPic);
                    else
                        aPic = noPicture;
                    DataRow newRow = datTable.NewRow();
                    newRow['Bild'] = aPic;
                    newRow['Beschreibung'] = dataReader['Beschreibung'].ToString();
                    newRow['Menge'] = String.Format("{0:f}", (double)dataReader['Menge']);
                    newRow['Einheit'] = dataReader['Einheit'].ToString();
                    newRow['Preis normal'] = normalPrice.ToString("C2", new System.Globalization.CultureInfo("de-DE"));
                    newRow['Preis jetzt'] = aktionPrice.ToString("C2", new System.Globalization.CultureInfo("de-DE"));
                    datTable.Rows.Add(newRow);
                    //aktList.Add(new ProduktAktion(noPicture, dataReader['Beschreibung'].ToString(), String.Format("{0:f}", (double)dataReader['Menge']), dataReader['Einheit'].ToString(), normalPrice.ToString("C2", new System.Globalization.CultureInfo("de-DE")), aktionPrice.ToString("C2", new System.Globalization.CultureInfo("de-DE"))));
            dataReader.Close();
            connection.Close();
            GridViewAktion.DataSource = datTable;
        protected void ButtAktion_Click(object sender, EventArgs e)
    und zwar schaff ich es einfach nicht, daß die Daten im GridView angezeigt werden !
    Daten werden alle geladen, GridView wird angezeigt aber nicht die Daten im GridView !
    Kann mir da bitte irgend jemand helfen ?
  • databind
  • datasource
  • gridview
