Hey
I have the problem that some effects don't rly work... as example if i put a shade on the clip it pulls the first video over the second. Is there any way to reset the start settings of the programm?
Regards Nik
Hey
Regards Nik
Just hold the Alt-Key when the application is starting. But as far as I know that's just for the settings. If you want to reset it completely you'll have to reinstall it.
So that means it worked in the beginning, but not anymore? Maybe the problem is something else. But I agree with DerJens, you might have to reinstall it.
Yeah just reinstall, you can save your projects and even your settings. Although you might actually not wanna save them due to your problem.
Hello
Regards Nik
