One of the most common mistakes in home residential window caulking is using the wrong type of caulk. Not all caulks are suitable for exterior use or extreme temperatures, so selecting the wrong product can lead to premature cracking https://kettlecontracting.com/home-residential-window-caulking/ . Another error is failing to clean the surface properly before application, which prevents proper adhesion. Applying caulk over old, damaged material without removal can also create weak spots. Over- or under-applying caulk can lead to gaps or excess buildup, both of which compromise effectiveness. Additionally, ignoring weather conditions during application—such as high humidity or extreme cold—can prevent proper curing. Always follow manufacturer guidelines for the best results.
Participate now!
